Bigger tires...
Old Jan 29, 2007 | 10:32 AM
foxrus14's Avatar
Default Bigger tires...
Since I am going with a 315 35 17 in the rear, will I need to do any type of modification to the car so that there are no rubbing problems? All advice is great. Thanks.
Russ
Old Jan 29, 2007 | 10:57 AM
junior28570's Avatar
with the proper offset .. no problems. 17x11 TTII's come with the proper offset .. I THINK it's 45mm. Tomzwheels (sponsor) would be able to answer for sure though.
Also, you'll want to install the wheels by jacking the rear axle as oposed to using a body lift ( your susp. will dangle and your tire will rest against the bump stop )
Old Jan 29, 2007 | 11:19 AM
foxrus14's Avatar
thanks.. i think i am going to have a shop do it cause I need to unmount my front tires and mount them on my new wheels. should I tell them to Jack the rear axle instead of using the body lift?
Old Jan 29, 2007 | 03:53 PM
dedge's Avatar
I had to cut off my bumpstops when I went to 11" rims.Which you better do if your running 315/35/17"s.
Old Jan 29, 2007 | 04:25 PM
Yeah .. have them jack it by the axle.
Again, make sure the wheels you choose (17x11's) are the correct offset. I can only speak for the TTII's and they WILL fit without clearance issues. I run 315/35/17 BFG DR's and they're the widest 315 DR I know of ... no issues at all (except traction ).
Old Jan 29, 2007 | 04:55 PM
Xsta Z 28's Avatar
No need to cut off the bumpstops . . . . . just lift the rear axle by the pumpkin and all is good.
