Wheel adapter problem
Old Feb 14, 2007 | 11:09 PM
Long Beach's Avatar
Default Wheel adapter problem
I picked up a set of hub centric 1" wheel adapters for my c5 thinspokes and when i put them on there is probably a good 1/4" of stud sticking out past the adapter. Do i have to buy shorter studs to make this work or can i cut the stock stud flush with the adapter? Has anyone else had this problem?
Old Feb 14, 2007 | 11:20 PM
Judas's Avatar
check to see if your rim as holes in that exact spot. 1/4" sticking out should be no problem. If your rim doesn't have holes there, then I'd take an angle grinder and cut 1/4" off the stock studs
Old Feb 14, 2007 | 11:44 PM
Long Beach's Avatar
I did not see any holes in the back of the rim, but then again i did not look verry hard. Ill see tomorrow, thanks
