Pro Star/ stud Q
Old Feb 26, 2007 | 12:58 PM
billybadd's Avatar
Default Pro Star/ stud Q
My '99 SS will see the track about once a month. I want 15x8 stars 5.5 bs.
I know ill have to grind calipers and run a 5/16 spacer. My Q is, will the factory studs be ok on the pro stars? Ill just be running rears at the track. No skinnies up front.
Old Feb 26, 2007 | 02:10 PM
99FBODY's Avatar
your studs should be fine it doesnt hurt to change them but i never had a problem when i was running my 15x10 draglites with stock studs.
Old Feb 26, 2007 | 03:18 PM
Steve Burger's Avatar
LS1TECH Sponsor
They will not pass tech if you get someone picky. Min of 2.5" or a 3" stud is needed.
Old Feb 26, 2007 | 03:56 PM
SiL3NtXWS6's Avatar
i had a 2.5in stud up front with 5/16 spacer. It is not long enough and will not pass tech. I now have 3inch studs up front and everything is fine.
