Little Bit More Height?
Old Mar 9, 2007 | 03:49 PM
theldog's Avatar
Default Little Bit More Height?
Can a get a tire with a little bit more height to it? I would like to raise the rear of the car .5", I'm running a 275/40/17. The car is lowered 2" all around and am now dragging a new exhaust setup. Wheels are enkei win wheels 17 x 9.5.
Old Mar 9, 2007 | 03:51 PM
SSNISTR's Avatar
Half an inch is alot to gain with a tire that will work with those wheels. The only tire that will work is a 285, but you might gain .2" if that....If your that low, change the rear springs IMO.
Old Mar 9, 2007 | 06:32 PM
Xsta Z 28's Avatar
Your ABS will hate you . . . unless the front and rear tires are close to the same OD.
Old Mar 9, 2007 | 07:20 PM
2002BlackSS's Avatar
Just do it the right way. Like everyone said in your thread in the Suspension section, change the springs.
