315 rears clearance question
Basically you will need to put them on and roll the fenders, drive a few miles then take them off and beat the hell out of any points where you can see the tires were rubbing.
Also because of the F-body tolerances, some of our rears may be off to one side or another enough to make it a problem, which is why an adjustable pan hard bar is a must when you lower the car. You might consider the adjustable lower control arms as well.
Some people have cut their bumstops off, but this isn't a good idea in my opinion, if it actually rubs just take a die grinder to it to trim it up a little bit.
If you completely remove the bump stop and ever hit a big bump, you could do serious damage to your rear suspension components.
