how do you get traction??
Old Apr 6, 2007 | 01:22 PM
01'WS6's Avatar
Originally Posted by rickssz
What tires u guys runnin and whats your 60 ft??
Tire size- 28 x 10.5 x 15
60'-1.4's
Old Apr 6, 2007 | 01:32 PM
BLK02TA's Avatar
I vote summitos for the best traction!!!
Old Apr 7, 2007 | 01:29 PM
cowboysfan's Avatar
pinion angle can help traction. also if you are getting traction with stock clutch and have atleast a cam/head swap now your getting traction cause you installed wider tires well, two things left to give. that rear end and/or clutch slippage.
Old Apr 7, 2007 | 03:44 PM
coolformula's Avatar
I think most have bad shocks and cheap tires. I have had pretty good look hooking with some decent tires and Koni's.
Old Apr 7, 2007 | 05:21 PM
purdueranger's Avatar
26x10.50 R16 ET Streets.
60' - 1.58 and the LS6 clutch didn't like that run at all.
I can't wait to see what times I can get with my Tex OZ700 in there.
Suspension setup here is all LG parts
G2 Springs
Torque arm
single adjustable LCA
adjustable panhard bar
bilstein shocks
Old Apr 29, 2007 | 05:27 PM
JSmee99T/A's Avatar
damn i wish i had 60 fts like that, my best is a 1.9x. now my best with my 4k stall is 2.2 lol but thats on street tires. Im looking to dr's or slicks not sure which is best.
Old Apr 29, 2007 | 06:11 PM
THE_SUPRA's Avatar
32x14 et drags
Old Apr 29, 2007 | 09:01 PM
SMOKKINU's Avatar
umm i had stock suspension, completley stock, i got a dana 60 rear with 4.56 gears and weld with 28x10.5x15's and i cut 1.4 60fts before i twisted the torque arm... now i got a SPOHN Adj TA thats body mounted. and just a sway bar and non adj boxed LCA's and boxed subframes
