ARP Wheel studs
Old Apr 15, 2007 | 10:49 PM
THE CHOP SHOP's Avatar
Default ARP Wheel studs
I am going to be replacing my rear axles with some superiors once they come off back order. I figure I might as well just buy new studs. I would like to go with a set of arp studs but I dont want studs that are not going to let me run the wheels I have with my McGuard tuner lugs. Has anyone got arp studs that did not require cutting to work like the ones listed for our cars? I noticed that the ARP-100-7710 on summits site are similar to stock size so I was thinking for trying them. Even though they say they are for a Honda. Has this been done before or is there some reason they would not work?
Old Apr 15, 2007 | 10:56 PM
fatdave's Avatar
yea ARP studs from Summit part number 100-7708 they are listed for our cars. I am also waiting on my superior axles ( should be here tomorrow) and those are the studs I ordered to go with them
Old Apr 16, 2007 | 09:09 AM
The ones listed for our cars would have to be cut down in order to work with my lugs. Has anyone tried the other ones I have listed in my first post? I will call summit to see if they say it can't be done. Also where did you get your superiors from?
Old Apr 16, 2007 | 09:55 AM
fatdave's Avatar
I ordered the axles from summit as well
Old Apr 28, 2007 | 09:36 AM
I wanted to post up my findings in case any one else had the same idea. I called ARP and they said that the Knurl diamater is what causes the problem and the only offering that will work with our cars is the ARP-100-7708. So that is what I ordered and I will just cut them down.
