15" Drag wheel question
Old Apr 28, 2007 | 11:56 AM
98Camarod's Avatar
Default 15" Drag wheel question
Typically does everyone have to modify the calipers and the fenderwell? Im thinking about getting rid of my c5 replicas and getting some of these. Also in the front with skinnies you need what size wheel and bs is most common? I know the rear is 7.5 bs with a 10 inch rim, but I'm not sure about the front.
Old Apr 28, 2007 | 02:00 PM
2_wacko's Avatar
With 15" yes you have to modify your calipers maybe not the fenderwell depending on what tire you run. The fronts are a 1.75 BS and you can grind or use 5/16 spacers. Jegs makes a 15x3.5 with 1.75 that some have said requires no grinding. If you do a search on drag wheels there is tons of info on this.
Old Apr 28, 2007 | 02:05 PM
98Camarod's Avatar
I found some info on it in the stickies, but I was wondering about the fenderwell issue more so than anything. I really do not wish to modify this. I dont have a problem with the caliper grinding.
