LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Wheels & Tires (https://ls1tech.com/forums/wheels-tires-17/)
-   -   315's and lowering?? (https://ls1tech.com/forums/wheels-tires/707660-315s-lowering.html)
2002RamAir May 2, 2007 08:46 PM
Hey guys,
Well its time for rims and tires and i wanna lower the car at the same time. I was wondering how bad will tire rub be in the back lowered with 315's? I am gonna use strano springs and koni sa's. Is it a do or a don't? I dont really wanna roll the fenders at this point...Opinions please!!!
Thanks
FASTERthanYOU May 2, 2007 09:14 PM
315's with prokit springs are no problem, my friend runs them on his trans am. dunno about a camaro tho
97 Z Me Go May 2, 2007 10:49 PM
Im rocking some stranos out back with qa1 shocks and full qa1s up front. The car sits 3 fingers all the way around the car. I have fikse fm5s with gs-d3 315s.
No rubbs for me.
Kyle
Donohue96M6Z28 May 2, 2007 10:54 PM
When I had a prokit. The tires barely rubbed. When I had sportlines. They always rubbed and I had to get my fenders rolled.
EchoMirage May 2, 2007 10:55 PM
im going with the exact same setup....315 rear, stranos and konis. havent put them all on yet though, but ive heard they should fit. going to be close though. i have a TA, the rims have the 50mm offset, rather then the ideal 36.
LS69TA May 3, 2007 06:22 AM
I had 315s with the G2 springs, which were roughly 2" drop, and didn't rub.
L$1W$6 May 3, 2007 08:11 AM
only other thing i would be worried about is hitting the y-pipe if it hangs low.......
RedRyder518 May 3, 2007 08:32 AM
Just to give you an idea of what I had to do to fit my GS-D3s. I am lowered on a Pro-kit so I had to do a bit more work to get them to fit nicely. Get you a nice hammer and start pounding away. After I thought I had enough, I had to pound some more. After applying a new layer of undercoating, I mounted the wheels and took it for a ride around the block and took them off again. You could see where you had to pound more by where it had rubbed off. I also had to roll my fender lips. It was quite a bit of work, but it was definitly worth it!
http://i25.photobucket.com/albums/c6...23/GS-D337.jpg
http://i25.photobucket.com/albums/c6...23/GS-D340.jpg
http://i25.photobucket.com/albums/c6...23/GS-D341.jpg
2002RamAir May 3, 2007 09:29 AM
Thanks guys!! I have a TA so I guess it is just more or less a hit or miss. O well I think Im gonna go for it. A little work for fat tires and a badass look works for me!
Donohue96M6Z28 May 3, 2007 09:39 AM
hey man. were you in san marcos yesterday(wed?)
L$1W$6 May 3, 2007 10:12 AM
RedRyder518 -- did you have to grind on the bump stop ??
trouse40 May 3, 2007 10:31 AM
prokit and 315 nitto did not rub!
RedRyder518 May 3, 2007 12:44 PM
No, I am in Oklahoma attending college. I must have a twin running around!
To L$1W$6, I did not grind my bump stops, but I do have to lift the rear using the axle. I may eventually grind the bump stop so I don't have to, but I always lift it from the axle anyways.
© 2026 MH Sub I, LLC dba Internet Brands
