315's and lowering??
Old May 2, 2007 | 08:46 PM
2002RamAir's Avatar
Default 315's and lowering??
Hey guys,
Well its time for rims and tires and i wanna lower the car at the same time. I was wondering how bad will tire rub be in the back lowered with 315's? I am gonna use strano springs and koni sa's. Is it a do or a don't? I dont really wanna roll the fenders at this point...Opinions please!!!
Thanks
Old May 2, 2007 | 09:14 PM
FASTERthanYOU's Avatar
315's with prokit springs are no problem, my friend runs them on his trans am. dunno about a camaro tho
Old May 2, 2007 | 10:49 PM
97 Z Me Go's Avatar
Im rocking some stranos out back with qa1 shocks and full qa1s up front. The car sits 3 fingers all the way around the car. I have fikse fm5s with gs-d3 315s.
No rubbs for me.
Kyle
Old May 2, 2007 | 10:54 PM
Donohue96M6Z28's Avatar
When I had a prokit. The tires barely rubbed. When I had sportlines. They always rubbed and I had to get my fenders rolled.
Old May 2, 2007 | 10:55 PM
EchoMirage's Avatar
im going with the exact same setup....315 rear, stranos and konis. havent put them all on yet though, but ive heard they should fit. going to be close though. i have a TA, the rims have the 50mm offset, rather then the ideal 36.
Old May 3, 2007 | 06:22 AM
LS69TA's Avatar
I had 315s with the G2 springs, which were roughly 2" drop, and didn't rub.
Old May 3, 2007 | 08:11 AM
L$1W$6's Avatar
only other thing i would be worried about is hitting the y-pipe if it hangs low.......
Old May 3, 2007 | 08:32 AM
RedRyder518's Avatar
Just to give you an idea of what I had to do to fit my GS-D3s. I am lowered on a Pro-kit so I had to do a bit more work to get them to fit nicely. Get you a nice hammer and start pounding away. After I thought I had enough, I had to pound some more. After applying a new layer of undercoating, I mounted the wheels and took it for a ride around the block and took them off again. You could see where you had to pound more by where it had rubbed off. I also had to roll my fender lips. It was quite a bit of work, but it was definitly worth it!
Old May 3, 2007 | 09:29 AM
2002RamAir's Avatar
Thanks guys!! I have a TA so I guess it is just more or less a hit or miss. O well I think Im gonna go for it. A little work for fat tires and a badass look works for me!
Old May 3, 2007 | 09:39 AM
hey man. were you in san marcos yesterday(wed?)
Old May 3, 2007 | 10:12 AM
L$1W$6's Avatar
RedRyder518 -- did you have to grind on the bump stop ??
Old May 3, 2007 | 10:31 AM
trouse40's Avatar
prokit and 315 nitto did not rub!
Old May 3, 2007 | 12:44 PM
No, I am in Oklahoma attending college. I must have a twin running around!
To L$1W$6, I did not grind my bump stops, but I do have to lift the rear using the axle. I may eventually grind the bump stop so I don't have to, but I always lift it from the axle anyways.
