325 50 15's
Old May 13, 2007 | 05:19 AM
snaketamer's Avatar
Default 325 50 15's
well im ordering all new 15x10 and 15x4 weld rodlites for my car come monday morning and was curious to know if im gonna have a problem with 325 50 15's fitting out back...the car is not lowered at all so shouldnt have problem there, but any input will help.
Old May 13, 2007 | 09:28 AM
Ping King's Avatar
youll have to cut the bump stops and maybe roll the fenders. my car is lowered in the back and i can tell you it was a lotof work to get these to fit.
Old May 13, 2007 | 09:36 AM
Wiz X's Avatar
with mine i had to cut the bumpstops off and grind down the calipers quite a bit and you will not need to roll the fenders but you will also need to grind down the rear control arms alittle
Old May 13, 2007 | 09:37 AM
Ping King's Avatar
i guess what they say is right. every car is different. Mine arent anywheres near the control arms at all, but closer to teh fenders.
Old May 13, 2007 | 09:42 AM
BADHAWK51's Avatar
The offset of your rims will determine what needs to be done whether it's fendors or control arms.
Old May 13, 2007 | 11:37 AM
xpndbl3's Avatar
i wonder if they'll fit on a thirdgen ....? anyone know?
Old May 13, 2007 | 11:41 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
What badhawk said... Welds will be more tucked in then Bogarts...
Pics of my 325's and Bogarts...:
http://psj.ls1tech.com/gallery/main....d=10&g2_page=5
Old May 13, 2007 | 12:59 PM
snaketamer's Avatar
the only thing is i can only get a 5.5inch backspacing with 15x10's, but if i want a 7.5inch backspacing i have to step up to 15x12's...think those will be too big? without seriously modding some stuff back there.
Old May 13, 2007 | 01:08 PM
carado1984's Avatar
i thought they made a 6.5 bs in those.. anyway.. the 15x12s with 7.5 bs should be very close to the 15x10s with 6.5 bs on the inside.. I have a feeling with the 325s youd have some rubbing issues since the 10" rims actually pull the tire in a little bit but the 12s would leave a slightly larger tread width.. i suggest you take your wheel off and do some measuring.
Old May 13, 2007 | 01:31 PM
snaketamer's Avatar
hmm well maybe ill just order and if they rub...MINI TUB IT!! lol
Old May 13, 2007 | 06:01 PM
LS1Tech Co-Founder
Oh and 15x4 welds don't typically fit on a 4th gen in front, won't clear the calipers. Folks typically run the 15x3.5's.
Old May 13, 2007 | 08:41 PM
carado1984's Avatar
lol i heard the kits arent that easy to install.. maybe you should get a bigger hammer first lol...
hey, just get um... they might not fit initially but you can make it work and when you do, its gonna look great.
Im getting 335/30 nittos ill send you pics.. ordering this friday will have them on next week!
Old May 13, 2007 | 08:52 PM
NA$TY-TA's Avatar
ARE you serious you started to grind on the control arms???
Thats why they make offset LCA's....
My Rears narrowed and i didnt need offset LCA's even though i have them....
My bumpstops and some metal behind them are gone.... Beating on the front lower part of the inside of the fender was needed....
Remember thats a 13.5" wide tire....
