Weld Prostar Question
Old May 31, 2007 | 10:47 PM
boostedbuford's Avatar
Default Weld Prostar Question
I just ordered a set of Weld Prostars 15x8 w/ 5.5 in backspacing, Ive herd you have to grind away the calipers.
How much grinding am I looking at?, is this gonna be a huge PITA?
Anybody with first hand experiance want to give me some insight in what are the best tools to use?
Old May 31, 2007 | 11:03 PM
chuckyt1's Avatar
I am in the process of putting Draglites on my car now. The grinding was way more than I thought it would be. I used some grease on the back of my wheels to check where they rubbed. Ended up ruining the caliper on the pax side, ( I think it had been replaced with some sort of cheap after market thing). I just used a die grinder from Home Depot. There are some pics on here somewhere that somebody posted... Good luck. Also... I would highly reccomend longer studs with those wheels...
Old Jun 1, 2007 | 01:09 PM
SJM Manufacturing Inc's Avatar
Change the order to 10" wheels. 8" wheels are too small for typical tire setups. If your concerned about grinding, as the above user damaging his caliper, you may consider our wheels.
Ours in essence using our Bogart wheels will be like removing an additional 50 lbs of converted static weight off your car and our wheels are show quality. The wheels are built for your car, not a one-size fits most made wheel.
Grinding questions and stud questions are asked literally every other day. Just do a search if you need more info.
