tape weights
Old Jun 1, 2007 | 06:14 PM
zrater's Avatar
Default tape weights
what do u think of tape weights for balancing tires, i got all 4 of my zr1
chromes mounted and balanced to day and one needed about 4 ounces
on one and the other about 3ounce and the two other were only 1ounce. what do u think about tape instead of crimp on weights...
Old Jun 1, 2007 | 06:17 PM
cookba's Avatar
TAPE ALL THE WAY. its so much cleaner looking, and they wont come off or fall off from the mounters not making sure there on good
Old Jun 1, 2007 | 06:35 PM
zrater's Avatar
thanks man, how much weight did some of your rims take, one of mine were
4 out and another was 3 out, is this normal..
Old Jun 1, 2007 | 06:45 PM
ZodiacZ28's Avatar
Ideally weights on the rim are better. But tape is the way to go. On my zr1's i run tape. youll mess up your wheels with the other ones. As long as the guy who did it knows what he's doing youll be ok. although 4 oz is a little much. Depends on what tire your running though. If its a good shop like discount tire they can road force the tires. They can actually tell where the wheel and tire should be mounted at. This can reduce the amount of weight> USUALLY> drive it and see how they feel. IF you notice any vibrations from the steering wheel its your fronts the floor its your rears.
cookba's Avatar
i think i had one that was like that. i just put it on the rear HAHAHA
Old Jun 1, 2007 | 06:54 PM
1BAD02WS6's Avatar
Tape weights work just as good as clip on....If you have a wheel with thin spokes and you dont want the ugly tape weights being exposed on the inside barrel of the wheel, you can ask for a "static clip on balance" . this is where only 1 clip is put on the inside lip of the wheel so it is invisible. It is harder to obtain a smooth ride from this type of balance, but can be done....but i work in a tire store so i can balance my wheels as often as i want till they are absolutly perfect lol
Old Jun 1, 2007 | 11:12 PM
hotsauce7's Avatar
how wide are ur wheels? Is there one strip on tape weights or two?
