What do 18's do to the speedometer?
Old May 7, 2003 | 04:47 PM
ArcticSS's Avatar
Default What do 18's do to the speedometer?
i have some z06's on the way, does it screw up the speedo any? thanks
Old May 7, 2003 | 08:18 PM
Gev's Avatar
Gev
Default Re: What do 18's do to the speedometer?
It depends...
I was going from a 245/50/16 tire to a 275/35/18 and it is off by a VERY small amount - totally negigible. I used this calculator to figure it out:
http://www.superford.org/garage/calculators/
--> Scroll down to Tire Conversion
If it's off by a big amount, say more than 4mph (use the calculator underneath the converter), go get the speedo recalibrated at teh dealership, or LS1Edit, or even an HPP3.
Hope that helps!
Old May 8, 2003 | 03:21 PM
Xsta Z 28's Avatar
a 275/35ZR18 tire is the exact same size overall diameter as the 275/40ZR17 tire factory on an SS.
I am running 18" all the way around, 18" x9.5" w/ 275/35ZR18 front and 18" x 10.5" w/ 295/35ZR18 rear. The od of the rear tire is a fraction of an inch taller than OEM, so the ODO reads kust a touch slow, like 1 mph slow when reading 60 mph.
Old May 11, 2003 | 10:12 AM
DrkPhx's Avatar
Here are tire size diameters:
245/50/16 = 25.64" tall. OEM F-body size
275/40/17 = 25.66" tall. OEM F-body size
275/35/18 = 25.58" tall. "Plus one" size
275/40/18 = 26.66" tall OEM C5 size
295/35/18 = 26.12 tall
Keep in mind with a .50" taller tire, you not only change the change the rear ratio slightly, but combined with a heavier weight tire and wheel
you will add rotating mass which will cost some hp. With that said I run 18"s on the street and switch to ET streets for track.
