Grinding calipers for 15" rim
Old May 7, 2003 | 08:20 PM
smokinHawk's Avatar
Default Grinding calipers for 15" rim
Started taking some off to get my 15" to fit.
how much and were do i need to focus on.
i got alot off, but it still rubs when i bolt them down
their welds draglights 15x10 with 7.5 bs.
pics would be good if you got them
thanks.
Old May 7, 2003 | 09:07 PM
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
Default Re: Grinding calipers for 15" rim
Jonathan when I did my grinding I concentrated on the areas on the rotor that stick out the farthest.Round off the outside corner of the rotor that is closest to the door.I put the rear end on jack stands,trans in neutral take some material off with grinder,put wheel on car spin it,if it rubs repeat until rubbing stops.Not a bad job just be cautious,better to make several attempts then take off too much all at once.Hope it helps
