Drag radial q's
Old Jul 1, 2007 | 09:38 PM
THEE PEWTER Z™'s Avatar
Default Drag radial q's
i want to put prostars on the rear of my 99 z with a micky drag radial .. i wanna go with a 10" rim but what offset do i get and whats the biggest dra radial can i fit on the rim and under the car
HELP PLEASE
Old Jul 1, 2007 | 11:12 PM
xpndbl3's Avatar
15x10 with 7.5bs, and if you're willing to beat the wells out then 325/50R15 would fit
Old Jul 2, 2007 | 02:23 PM
andy670ho's Avatar
I too would like more info on this, looking for info on caliper options or is grinding neccessary with 15 inch wheels? What about skinnies up front, what backspacing should we run?
Old Jul 2, 2007 | 07:38 PM
1nastyss's Avatar
Would also like to know....free bump for ya
Old Jul 3, 2007 | 02:11 PM
andy670ho's Avatar
Anyone? someone must know!
Old Jul 3, 2007 | 03:13 PM
stevensLS1's Avatar
i believe you can run spacers up front with out grinding the front calipers. rears have to be grinded. 15x10 with 7.5 bs and the fronts are 15x3.5 unsure of the backspacing tho. 325s out back with some work will fit.
Old Jul 4, 2007 | 01:14 AM
LT1's Avatar
LT1
15X10 rear with 7.5 BS for camaro's
15X10 rear im not sure about firebirds ive heard 6.5 BS works for them.
15X3.5 front with 1.75 BS camaro / firebird
LS1 f-body's with LS1 brake caliper need to be grind down, to fit with no spacers. but if you run spacer's less grinding and need to run longer stud's.
i test fit my 15X10 pro star they fit fine with little grinding. To fit 325/50R 15's on the rear i had to cut part of the bump stop off, then a little BFH. and now it fits nicely no issues at all.
