9" Speedlines with 315 rears?
Old Jul 1, 2007 | 10:33 PM
Ricks99ls1's Avatar
Scammer Alert!
Default 9" Speedlines with 315 rears?
This has been covered a million times i am sure, but i have heard some people say yes and some say no, can i use a 315 grag radial on the rear of my 17x9 speedline? if need be i will grind the bump stop and bang the side wall? would this work or not? if not is the 315 just to big or why wont it work?
Old Jul 1, 2007 | 11:08 PM
Ricks99ls1's Avatar
Scammer Alert!
anyone please chime in, i am getting tires tomorrow and need to know
Old Jul 1, 2007 | 11:16 PM
SSilverSSurfer's Avatar
the sidewall will start to roll over which is not good. and you'll get irregular wear, just go with a different size
Old Jul 1, 2007 | 11:26 PM
Ricks99ls1's Avatar
Scammer Alert!
even if my car isnt lowered it will do this? and whats the next biggest size i could go?
Old Jul 2, 2007 | 12:49 AM
yeah it will. the main problem with rubbing inside the wells is the wheels no the tires. the tires rub on the fender lip which is why they need ot be rolled if you do a 315 on a 11" wheel combo. i wouldnt go any wider than a 285 40 17 on your 9" wheel.
Old Jul 2, 2007 | 04:11 PM
Xsta Z 28's Avatar
315's require a 10.5" wide or wider wheel.
A 9" wheel the PERFECT tire is a 275/40ZR17.
The widest to run safely: 285/40ZR17
