ThunderRacing ARP wheel studs..
Old Jul 9, 2007 | 07:18 PM
renxwar's Avatar
Default ThunderRacing ARP wheel studs..
Search isn't working, and doing a cz28 search brought me absolutely nothing.
http://www.thunderracing.com/catalog...vid=3&pcid=147
I need to replace one of my front wheel studs, on stock ZR1 style SS rims. Which length do I need? Thanks.
Old Jul 9, 2007 | 07:50 PM
myfast70's Avatar
I would go with the shorter of the two. They still may be too long for what you're doing though. I would not recommend cutting them.
Old Jul 9, 2007 | 08:11 PM
SiL3NtXWS6's Avatar
2.5 will work fine. I ran 2.5 up front for a while with stock wheels, but i run 3.25 for my drag wheels now.
Old Jul 9, 2007 | 08:32 PM
renxwar's Avatar
So should I go with these, or get stock replacement?
Old Jul 9, 2007 | 08:49 PM
DopeFedZ's Avatar
The shorter of the two are still about half an inch longer than the stock studs. I have the 2.5" studs on the front of my car and the stock ones on the rear. I was still able to use the stock lug nut and black plastic cover when I had my ZR1's.
Old Jul 10, 2007 | 01:24 AM
LT1's Avatar
LT1
how many of them are broken? if i were you just get the stock replacement there cheaper and theres no reason to get the ARP's, because your zr1 rims bolts on using the center hub, so theres not as much tention on the lug studs.
