speedo reading w/ 18s
Old Jul 13, 2007 | 01:36 AM
whitedevilWS6's Avatar
Default speedo reading w/ 18s
so what will 18s do to the speedo reading on my car? i've got an M6 so i'm assuming i have 3.23s (or do i?) so what if i put in 3.73s would that fix it or just jack it up worse?? need i move my thread to another forum? tried a search and didn't find anything useful, random results in random forums.
Old Jul 13, 2007 | 03:49 AM
Donohue96M6Z28's Avatar
if your running 18s, you can run tires that will keep your speedo almost the same as factory... IE 275-295/35/18 etc... by the way, a 6spd stock comes with 342s.
Old Jul 13, 2007 | 08:21 AM
Xsta Z 28's Avatar
Wheel diameter has absolutely nothing to do with your speedometer . .
Tire diameter is the issue.
For example if you use the tire calculator up in the stickie, you'd see that a 275/40ZR17 is virtually the exact same OD as a 275/35ZR18, so no speedo calabrations would be needed.
The only way to correct a speedo is with a computer programmer.
Changing differential gears would never help in that situation.
Old Jul 13, 2007 | 05:24 PM
awesome thanks. i wanted to put 18x9.5s on my T/A and lower it using ground control coil overs. no clearance issues with anything there are they? also, i know that you're not supposed to go too big with the tires on only 9.5s but i can't find any wider C6-ZO6s. i don't suppose i would screw myself over by mounting 285/35s on there would i? i want to be able to rail corners but i want a wide enough tire to hook up when i pump up the power on my car. tires i was looking at are Nitto 555 extremes. maybe they'll hook up fine despite only being 285s?
Old Jul 16, 2007 | 02:34 PM
Xsta Z 28's Avatar
275/35ZR18 is best . . . A 285/35ZR18 could be run . . .
