Quick Size Question Please Answer
Old May 14, 2003 | 04:48 PM
Rice Burner's Avatar
Default Quick Size Question Please Answer
There is a bid on Ebay I am interested in. Wheels and tires...I am not sure if they will fit. My car has been lowered with BMR springs...These are the dimensions of the wheels285-30ZR-18 Hoosier tires and the rears are P335-35ZR17 Hoosier tires. Fronts are 11 inches wide, the rears are 13 inches wide. Will these fit without body modifications? How can i squeeze these in? Thanks
Old May 14, 2003 | 05:39 PM
Default Re: Quick Size Question Please Answer
The front wheels are 10.5 inches according to the guy. Arent they 9.5?! The rears are KinesisMotorsport three peice wheels 12.5 inches wide...
Old May 14, 2003 | 11:12 PM
MJMZ28Cvt's Avatar
As far as I know 9.5 is the biggest you want to put on the front. On the back you can fit 11s with some banging in of the fender wall. I doubt you could get anything bigger than 11 on without major modification.
Old May 15, 2003 | 12:51 AM
OctaneZ28's Avatar
There's a guy on here (I forget who) that's running 17x11 wheels on all four corners.
This is on a Trans Am... they apparently have a little more room in the wheel wells than Camaros do.
I think his car is stock height though if I remember correctly.
