Wheel widening math/opinion needed
OR
Should I save the cash and just keep the 9.5" width, run a 275 MT radial on them with a 1" width wheel adapter to push the rears out to create the look of wider rears?
I want the tire to align near flush to the fender (like a 315 would look on a 17x11 ZR1 wheel), but I want the car to hook. I don't think I'll see much difference in hooking between the 275 and the 315, but I thought I'd ask about that as well.
If the wheel were a 54 mm offset 9.5" wide wheel. You are adding 1" to the rear of the wheel, so the center line of the wheel moves 1/2" or 12.7 mm. The offset changes by that much, so now the actual offset would be 66.7 mm. A good offset for a 10.5" wide wheel is around 44 mm. Therefore 66.7 mm - 44 mm = 22.7 mm or ~ 7/8" spacer.
Make sence?
Do you think keeping them 9.5 wide and running a 1" adapter to bring them flush to the fender would look dumb with a wider 275 tire? Like a MT or BFG DR?
The wheels are 54 mm, 9.5" wide wheels. My 9.5" wide wheels have 38 mm offset and I really like the look, so:
Mathmatically, 54 mm - 38 mm = 16 mm or ~ 5/8". Any thicker the wheels will start to stick out and cause other problems.
BTW, after searching I've found several firebirds/ta's on the site that run .5" spacers to push the wheels out in the rear, and it didn't look that bad.
Sorry, that makes no sence at all . . . . spacers aren't used to make the wheels look wider . . . they are used to place the wheel in the wheel well better, and improve the looks of the car . . .
