zo6 rim question
Old Jul 23, 2007 | 07:05 PM
Ricks99ls1's Avatar
Scammer Alert!
Default zo6 rim question
Ok i have a set of 18x10 aftermarket zo6 rim coming mounted on 295/30zr/18 kuhmo for the rear of my car, has anyone ever successfully used this tire without having to massage the quarter panel wall? if you have any pics thatd be great
Old Jul 23, 2007 | 07:09 PM
six_string_wiz's Avatar
I have 18x10.5 with 275/35s and the only thing I ever needed to do was grind the edges of the bumpstops down.They were hitting the inner lip of the rims
Old Jul 23, 2007 | 09:19 PM
Ricks99ls1's Avatar
Scammer Alert!
anyone else, please?
Old Jul 23, 2007 | 10:46 PM
Texass683's Avatar
I run a 275 and have the 18x10.5 and i had to use the BFH method on the inner wheel well. No quarter panel massaging. From what i hear you dont need it unless you move up to a 315. Try a search its hit or miss but sometimes works.
Old Jul 23, 2007 | 10:49 PM
Ricks99ls1's Avatar
Scammer Alert!
well my fronts are 17x9.5 and the tire is 275 40 17 which should be fine, so my rears will be ok you think.. with the 295 30 18 and a 10 inch rim?
