315 size tire.........Help
Old Aug 15, 2007 | 08:20 AM
2jett's Avatar
Default 315 size tire.........Help
Looking for some new tread.. the question is what size... want a wider tire than the stock 275.. My car Arctic wht 02 SS stock height and suspension. what would you all recomend ???????
285/305/315?????????
Dont want to have to do The BFH mod....
Old Aug 15, 2007 | 08:39 AM
Xsta Z 28's Avatar
With stock wheels a 275/40ZR17 is the best. A 285/40ZR17 is the biggest.
Several will follow after me and say bigger tires fit . . . but a square peg will fit in a round hole if you hit it hard enough too . . .
Now with wider wheels, your options change.
Old Aug 15, 2007 | 10:24 AM
2jett's Avatar
ok talked with tire rack, they told me to run the 285 size I needed to have 9.5" wide rims......
Is that correct, who is running the 285 on stock 17x9 rims..
Old Aug 15, 2007 | 11:18 AM
SS1156's Avatar
You can safely run a 285 on a 9" rim. Do you really think 1/2 " will make that much of a difference? A 285 is 10mm wider than your current tire, doesn't seem worth it to me. There are a lot more choices of tires in the 275 size then 285's. Good luck.
Old Aug 15, 2007 | 12:12 PM
TheLS1Kid's Avatar
Just do the BFH so you can run some fat rubber out back.
You won't be disappointed with the outcome. They look killer.
Old Aug 15, 2007 | 02:13 PM
Xsta Z 28's Avatar
Per manufacturer specifications a 285 necessitates a 9.5" wide wheel.
If you want a nice beefy 275, look at the Goodyear GS-D3.
