Will these wheels fit correctly? (Offset question)
Front: 17x9 +45mm Offset
Rear: 17x10.5 +44mm Offset
I found some sweet wheels with these dimensions, and am curious if they'll fit correctly. Thanks, Shawn
So yes they should fit fine, and you could always use a very thin spacer on the front if you wanted to move the front wheels toward the outside to even up the offsets some.
-Shawn
