Help! Changing wheel studs on a moser 12 bolt
Old Sep 5, 2007 | 07:48 PM
BBBBadSS's Avatar
Default Help! Changing wheel studs on a moser 12 bolt
Searched, nothing. How do you change the wheel studs on a moser 12 bolt? I can just get the stock length out but cant get the longer arp stud in. Do I need to pull the axle out alittle? The studs that came with the moser must be harder than stock (10.9 grade) but they are 7/8" shorter than the arp's im putting in.
Old Sep 7, 2007 | 11:31 AM
WhiplashDVD's Avatar
If you have 4 channel abs pull the sensor out and put them through that slot. If you have 3 channel start pulling axles.
Old Sep 7, 2007 | 11:37 PM
LT1's Avatar
LT1
i had to pull the axles to do mine, its not bad at all, pulling the axle out is actually the right way to do it, and personly i think its much faster and easyer because youll be able to knock out all the studs at one time.
Old Jan 7, 2008 | 11:58 AM
fastenough's Avatar
are moser 12-bolt studs press in or screw in? I need to get 3.25 studs but I am not sure which ones I need.
Old Jan 7, 2008 | 12:20 PM
fastGBcamaro's Avatar
They press in. Like Whiplash said, if you have 4 channel abs then you just rmove the sensor and slide the new stud through the hole. Then just take a junk lug nut and a bunch of washers and pull the studs through. Not very hard at all. But if you have 3 channel then pull the axels and get the new studs pressed in.
Old Jun 26, 2012 | 05:56 PM
GMMGWS6's Avatar
is there anyway to swap out studs with out pulling axles ????
