275 on 9"?
Old Sep 14, 2007 | 01:39 AM
Mercerius's Avatar
Default 275 on 9"?
I'm getting a set of 17x9 10 spoke SS wheels for my T/A. I believe the stock size tire runs 255/45/17, right? Those will run in front for sure, but I'm wondering if it is possible (safe/cool) to slap on 275/40/17 on the rears?
I know it would clear and I know the centerbore is smaller on the 98+ f-body wheels. Had a similar problem with the oe Y2k C5s I had and got spacer/adapters to take care of that.
Thanks!
Old Sep 14, 2007 | 01:49 AM
YoungGunLs1's Avatar
You can run 275's on the front and rear on that size rim. 9" and higher are safe to run 275's...I would recommend running all 4 tires that size too, that way you can rotate tires.
My ZR1's are 17x9.5 and I run 275's on all 4.
Old Sep 14, 2007 | 11:29 AM
bricez28's Avatar
yea i run 275's on the front, i have 9.5, but im sure its fine
Old Sep 14, 2007 | 11:31 AM
michaelg589's Avatar
Stock SS tire size is 275-40-17 all the way around. not 245. 275-40-17 is what you should run.
Old Sep 14, 2007 | 01:36 PM
BIG_T's Avatar
like the others say run 275/40 all the way around mine are 17x9.5 wheels and i fit them fine
Old Sep 14, 2007 | 05:27 PM
Switchblade's Avatar
Thanks!
Camaro SS with the 17x9 rims (10 spoke, ZR1, etc) are equipped from the factory with 275/40R17's. Ditto for WS6 T/A's.
Old Sep 15, 2007 | 02:54 AM
Mercerius's Avatar
Well 275/40s all around it is!
Many thanks, everyone!
