ABS inop
Old Sep 14, 2007 | 04:16 PM
colby72olds's Avatar
Default ABS inop
my ABS light is on, i know because of my 18's and tires. Would the only way to correct it, be to put my factory 16"s and 245's on? How bad does it affect my ABS? I can deffiently tell the wheels/tires weigh alot more than the 16"s.
Old Sep 14, 2007 | 04:56 PM
Xsta Z 28's Avatar
Are your tires dramatically different in OD??
ABS, is off while that light is on, so in a panic stop no ABS, just locked brakes.
Old Sep 14, 2007 | 05:30 PM
Dex's Avatar
Dex
If all the tires are the same height there shouldnt be a problem. What sizes are you running? What code is it?
