Backspace question after reading sticky...
Old Sep 24, 2007 | 12:31 PM
White.Lightning's Avatar
Default Backspace question after reading sticky...
Hey everyone,
I am looking at a set of wheels. After reading the sticky above (excellent writeup) I am still finding myself confused about the backspacing of the wheels. It shows that with a 9.5" wide wheel, +38 to +48 mm offset, you could run a 275 tire front or rear. My question is, at what backspacing does this hold true? Is this backspacing the same for all examples in the sticky?
Thanks
Andy
Old Sep 24, 2007 | 04:50 PM
jimmyducati's Avatar
the backspacing is the offset, just a different term
Old Sep 25, 2007 | 04:20 PM
Xsta Z 28's Avatar
Exclamation
Incorrect . . .
Offset is the distance from the center line of the wheel to the backside of the lug mounting plate in mm.
Backspace is the distance for the rear most surface of the wheel to the lug mounting plate.
Slightly related. . . . One can get an approximation on the BS from offset assuming the rear rim bead is 1/2" thick.
A 9.5" wheel with a 38 mm offset should have ~ 6.75" of BS
A 9.5" wheel with a 48 mm offset should have ~ 7.14" of BS
Old Oct 6, 2007 | 07:45 AM
69TA's Avatar
Yeah BS was way to easy for the common person to understand so the wheel manufacters all decided to go with the offset specification.
And if that was not bad enough I also found out the hard way that there can be variances in rim widths by as much as
1/4" this is with the same manufacturer with the same size rim just different model.
