need help on studs and spacers size
Old Sep 30, 2007 | 08:25 PM
aDaM Ws6's Avatar
Default need help on studs and spacers size
Ok, I got Nitto's 305/35/18 on my z06 wheels 18x10.5 on the rears. Now when I put them on I noticed it rubs against the inner fender well. So I took off my wheels and in the process, a stud broke off. So I did bfh method and it helped on some parts of the rubbing but not all. So did some more bfh, didn't help me much. So now I'm going to order arp studs and get some spacers.
Problem is I don't know which stud sizes to get (12mm X 1.5, 3.25" length )?? and which spacer size to get.
Thanks for any help,
Adam
Old Sep 30, 2007 | 08:39 PM
sixvi6-camaro's Avatar
depends the 3.25" long ones are very.. very long.. they will stick out of the rim. if you are not running 15" drag rims I'd just get the shorter 2.5" ones which are still longer than stock but yes the 12mm x 1.5 is the correct size as long as its the set made for f-cars and vettes.
there are pics of the 3.25" long ones on this thread..
https://ls1tech.com/forums/drag-racing-tech/744837-grinding-calipers-101-a.html
