need tires
Old Oct 5, 2007 | 11:13 AM
02 hawk's Avatar
Default need tires
I have a 02 firehawk, looking to buy drag tires and rims for the rear, just to be used on the drag strip, any suggestions....
Old Oct 5, 2007 | 02:10 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
You got a lot of choices. Bogarts are the most expensive but are a direct fit on F-bodies and they are very nice wheels. You also have Centerline and Weld as well. Some have run Centerlines with no grind of the calipers but when you run Welds you will have to do some major grinding
Old Oct 5, 2007 | 03:44 PM
TheLS1Kid's Avatar
If you have the money, go with Bogarts.
They are light, look badass, and bolt right up with no grinding.
