Low Trac light with skinnies??
Old Oct 7, 2007 | 01:17 AM
NVR_ENUF's Avatar
Default Low Trac light with skinnies??
I just got around to installing the slicks/skinnies on the SS today and took it for a quick spin...... (beat run)
I find that when I'm braking 'slightly' hard, the LOW TRAC light will come on and the ABS kicks in. ASR is turned off also....
I know this is because of the difference in wheel speeds from the 27" tall E/T Streets and the small skinnies, but the question is..... How do I avoid this?
Do you guys disconnect the ABS sensors in front or something when you have the skinnies on? Whats the trick?
Is it something I can fix with HPtuners?
Any helpful advice is greatly appreciated!
Thanks
Brian
Old Oct 7, 2007 | 08:20 AM
SJM Manufacturing Inc's Avatar
Disconnecting a sensor will not work. You could remove the ABS fuse, but you'll leave your braking system handicapped.
...this is one reason why our ABS delete kits are so popular.
Our kits won't take care of the lights on the dash...but it will control your braking issue. With our kits, your able to tune your brake bias...something you couldn't do before. It will also drop 15-20lbs of weight, increase air flow and clean up the engine bay.
Good luck.
