Weld Racing Wheels
Old Oct 12, 2007 | 10:13 AM
TheMRguy's Avatar
Default Weld Racing Wheels
I got a new set of weld racing wheels for my slicks i got with my car when i bought it. I get the tire mounted on them and then later mount them to my car. They bolt up and i check the clearence for the calibers and its hitting them. So it wont move or anything. They sent me the wrong backspacing so its hitting the caliber. I have a 1inch spacer thats the seems to be like another rotar u bolt on top of ur own and has its own studs. Should i try that and take it to the track or try to get a diff set of wheels?
Old Oct 12, 2007 | 10:23 AM
blueeyeddevil141's Avatar
15" wheels rub....you have to grind the caliper.
Old Oct 12, 2007 | 11:03 AM
BIG_MIKE2005's Avatar
^^ Yep, they won't fit without grinding. Give the wheel specs & we can tell you if the back spacing is correct or not. But even with correct back spacing grinding is still needed.
Old Oct 12, 2007 | 11:05 AM
Camaro396's Avatar
you need to go back to grammer school before you play cars any more.
