Looking for a generic billet centercap
They are meant to be run with the factory lug cover plate to hide the lugs and hub knockout. I like them alot more cover off, but you have that hole in the center for the nasty hub to stick through. My idea: I want to get some blank forged or billet center caps that are just larger than the I.D. for the center hole. I am going to drill through the back to the front and weld the new cap to the wheel over the hole. I am about at the point of going to a machine shop and getting 4 made. Which will cost WAY more than it should.
Question if you weld the centercap to the wheel how will you have the tires balanced from then on since the machine I've seen them used always has a hub that goes thru center of the wheel.
