Pro Star Offset Error?
Old Nov 9, 2007 | 12:23 PM
Floader's Avatar
Default Pro Star Offset Error?
just got a new set of Pro Stars from the local dealer. Boxs both say 15x10 7.5BS. I get them both out of the boxes and set them on the floor one is 1/8th or so wider than the other. Mabey this is a slight manufacturing error but one of the wheels has a sticker on the inter half of it that says "Pro Star - Inner 15x7.625". didnt even know there was such backspacing. Emailed Weld and no response so far. How much of a problem would this cause anyway... what a hassle
Old Nov 9, 2007 | 11:17 PM
dlandsvZ28's Avatar
Send them back. Summit took one of my Centerline's back - no questions asked.
I would also mount both and spin them on a tire balancer before mounting or balancing and measure run-out with a dial indicator to make sure the one's you keep don't wobble. Just an 1/8 of an inch looks ugly. Nothing looks worse than a big tire mounted on a rim that wobbles because the rim isn't straight.
