Widened WS6 wheels.
http://www.tirerack.com/tires/Compar...t=All&x=69&y=7
Try this link, not sure if it will work or not.
You may even be able to buy some front dented rims cheap or for free even and send them to save you some big bucks.
Also, you don't want to use longer studs and spacers over 1/4" or so. If you can do 3/4" of spacing you can have custom adapters made for $40ea. The adapter bolts to the axle and then the rim bolts to it. This way is super strong. You just need to make sure the rim has room on the back side for the original studs to clear. Here's a pic of my rims and they have plenty of space for the studs.
BTW, the new rims look great, Ron. Lot's more attitide, plus they are more flush with the fender lip like the front rims.
No thank you, ill spend my money else were on a pair of MT drag radials that will hook
315 nittos are nice, they are affordable, they last awhile and look good while still letting the car take turns well
