biggest 40 series tire?
Old Nov 13, 2007 | 10:15 AM
DBanks's Avatar
Default biggest 40 series tire?
Hey guys,
The back of my Camaro is raked pretty high because of the drag racing air bags and springs in the rear. I have BFG Drag Radials in the rear (315/35/17) and they're very small -- look goofy -- and do not fit the rear wheel well at all.
So I'm thinking outloud here... what is the widest 40 series tire I can put in the rear? a 315/40/17?
Thanks in advance,
-Dan
Old Nov 14, 2007 | 11:41 AM
DBanks's Avatar
no one is running a 40 series tire in the rear?
I find it hard to believe....
Old Nov 14, 2007 | 12:15 PM
Discount Tire's Avatar
The largest 40 series 17 tire I see in my system is a 285.40.17. They are only .3" taller and they are 1.18" skinnier.
The only tire I see close to fitting your wants/needs would be a 335.35.17 but you would have to test fit it to see if it will fit, it is .79" wider and .55" taller.
Old Nov 14, 2007 | 12:27 PM
black01_WS6's Avatar
a 285/40/17 is the widest, but is limited in tire selection.
we are talking about a 17 inch rim right?
Old Nov 14, 2007 | 01:05 PM
DBanks's Avatar
Thanks guys!
I did make the post a little premature before conducting proper research. I think I am going to stick with a 315/35 and just remove some of the air in the bags. It seems like its the best bet. Nothing beats the look of the 315 from a side profile or rear vantage point. Yes, we're talking about a 17 inch rim.
Thanks again.
-Dan
