2004 Gto
Old Nov 14, 2007 | 05:01 PM
mopowrmike's Avatar
Default 2004 Gto
do any of you guys out there have aftermarket wheels on your gto? if so what bolt pattern did you use 114 or 120 bolt pattern? could we even go with a 17x9 in the rear or are we stuck with only using a 8" wide wheel?
Old Nov 14, 2007 | 09:47 PM
Xsta Z 28's Avatar
5 x 120 is the bolt pattern . . . Up front 8" is the max. 9" can fit in the rear, but a tire bigger that 275, will force some body mods, such as rolling of trimming the quarter lip.
I have Fikse's on mine.
Old Dec 7, 2007 | 07:41 AM
mopowrmike's Avatar
would an 18x8.5 fit in the front without rubbing the strut?
