Whats a cheap drag only setup?
Old Nov 27, 2007 | 03:16 PM
STRIPSTAR's Avatar
Default Whats a cheap drag only setup?
I may buy a full set of wheels and tires for strip. Whats a choice for decent but cheap setup? The ccw drag pack and tires is way to much $
Old Nov 27, 2007 | 04:24 PM
Photochop's Avatar
Well I'm sure I'll be flamed for this, but I don't care.
The summit star wheels are pretty economical and fit our cars pretty well (less grinding that prostars, and look virtually identical). They use stock lugs and studs and don't require spacers. If you're going track only you could get those rims and run an et front or similar lightweight front tire on them to help compensate for them weighing about 4 lbs heavier per wheel up front. Then run a slick in the rear instead of a dragradial to save weight there. They come in a 15x4 and a 15x8, plenty of wheel for a 28x12.5x15 et street style tire.
Old Nov 28, 2007 | 09:05 AM
STRIPSTAR's Avatar
Why would you get flamed for that? Weight? Well there cheap so soemthing should give. how much grinding is involved?
Old Nov 28, 2007 | 09:46 AM
Photochop's Avatar
Yeah I've mentioned them a couple times before and people gave me crap about the weight of them, only 4 lbs more on the skinnies than a prostar. Even though you can minimize that weight gain by going with a lighter weight front tire. I think the 15x8 rears weigh the same as a 15x10 prostar (or very close).
The rears don't take much grinding at all. I already had clearanced my LT1 rear calipers (lt1 3 channel swap rearend in the car currently) for 15x10 prostars on my car a few months back so they fit no problem with plenty of clearance. It doesn't take NEAR as much material off as even a 15x8 prostar does. The fronts are iffy. Most people have no problem with them fitting. BUT if you just changed your pads recently or plan on doing it in the near future, be prepared to take a little off the front calipers, depending on pad thickness.
Old Nov 28, 2007 | 10:13 AM
BIG_MIKE2005's Avatar
What about the Jeg's version of these wheels?? I think they are only like $90 a piece for the fronts & look almost identical to a Prostar also.
Anyone know how well these fit on both front & rear?? I'd imagine about the same as the Summit brand but I was just wondering if anyone knew for sure from personal experience.
Old Nov 28, 2007 | 10:32 AM
1_bad_TA's Avatar
Does anyone know the actuall weight of the Jegs or Summit wheels? I was thinking about getting a set.
Old Nov 28, 2007 | 05:11 PM
SSkillz's Avatar
The jegs wheels are what you want then! Dont know the actual weight but they didnt feel much diffrent from my prostars. Anyone ever get some # from both?
