Tire Help!!
Old Nov 28, 2007 | 07:30 PM
BlkBird2000's Avatar
Default Tire Help!!
When it says Treadwear/Temperature/Traction:360AA Does that mean 360AA has more tread life or more of the tire on the ground compared to a 300AA tire. If that makes any since to you? Thanks for your help!
Old Nov 28, 2007 | 08:09 PM
staringback05's Avatar
yes in theory.....however alot of companys will only test the min. to make the feds happy....in what comparison of tires are you seeing this?
Old Nov 29, 2007 | 06:16 AM
Nitto NT555 and Falken FK 452s/Falken ZE-512
Old Nov 29, 2007 | 09:45 AM
dontshakepandas's Avatar
The major problem with treadwear ratings is that there is no set standard. So a 300 rating for one company could actually be better than a 400 rating for another company. The companies only use their own tires in comparison, so if you are using this to compare different brands of tires, its pretty much useless.
