5 hrs. of grinding=
Old Dec 3, 2007 | 03:00 PM
subhumanzz's Avatar
Originally Posted by Nine Ball
5 hours? Did you use a hand file or what? You can buy a $35 disk grinder at most tool stores and knock it out in about 10 minutes or less per wheel.
hahahaha! i feel bad for whoever is driving the car if you can grind them in 10 minutes. because the wheels arent gonna turn. you must have never ground down calipers for a 15x10 before and if you did infact do it in 10 minutes go buy new calipers because you hacked yours up! ask anyone who has done it how long it takes. i was being cautious and not wanting to remove more than i had to so i did alot of fitting, grinding, fitting, grinding....
Old Dec 3, 2007 | 03:11 PM
Havok2's Avatar
Nine Ball "5 hours? Did you use a hand file or what? You can buy a $35 disk grinder at most tool stores and knock it out in about 10 minutes or less per wheel. "
10 mins?? or less? not possible. your saying you ground both sides to get prostars on in 20 mins total? it took me 45 mins per wheel or so. no way you did it in 1/5th the time i did. your grinder have "vtec"?
Old Dec 3, 2007 | 03:15 PM
Floader's Avatar
I can see the point of about 10 mins... took half an hour to do the first side, and 10 mins or so on the next side. Once I could see what needed to come off I just ground the hell outa it, then buffed it up to look nice.
Old Dec 3, 2007 | 03:20 PM
Camaro396's Avatar
no grinding here
Old Dec 3, 2007 | 03:25 PM
phantomLT1's Avatar
LMAO
He should have took a video. I wish I would have it looked like a monkey F**Kin a football . I got my old man to help me beat the fenderwells I would hold the board in place he would swing the hammer lots of trust involved. But it did not take me 5 hours to grind with a bench grinder.
Old Dec 3, 2007 | 03:29 PM
SIC LSX's Avatar
Yeah my 1st wheel took 40mins & 2nd wheel took 20mins! Once you know about how much to grind down its really easy. 1st time grind then put wheel on. The take back off grind some more over and over a few times then your done LOL. 2nd side grind once put wheel in once
Old Dec 3, 2007 | 03:45 PM
subhumanzz's Avatar
Originally Posted by phantomLT1
LMAO
wow. how did you fit a bench grinder in there? no one is talking about pounding the inner fenders!
Old Dec 3, 2007 | 03:51 PM
BigKap94z's Avatar
Yeah it takes $10 minutes if your not careful and just go at it and grind away everything. It took me a long, long time to do mine as well. Trial fitting along the way, so I didn't need to grind anymore then needed. A couple weeks later I changed the brake pads and went to put the wheels on again and had to grind even more.
