will my Y2Ks have problems?
Old Dec 21, 2007 | 10:16 AM
fast01z28's Avatar
Default will my Y2Ks have problems?
before anyone says anything, i have seached and still havnt found a straight forward answer to this.
This morning i installed some OEM Y2Ks. i used 3mm spacers (the tires shop said its not safe to go any larger without using longer studs) and everything seemed to clear. the bump stop was close when i mounted the wheel but once the car came off the jack the stop ended up in the middle of the wheel, and it DID clear even when it was next to the tire.
will I have any problems? I know that when its idle its clear, and nothing seems close enough to hit when the suspension travels, but you guys all know better than anyone.
to avoid posting the same pics all over this website, go to https://ls1tech.com/forums/showthrea...80#post8345580 to see pics.
