what will fit?
Old Jan 3, 2008 | 04:11 PM
black383's Avatar
Default what will fit?
not sure if this right section... but will a 315 fit under my '94 Z28 with ZR1 rims?i am lowered...what would i have to do to get them to fit if they wont
Old Jan 3, 2008 | 04:23 PM
TXws6's Avatar
yeah lots of people do it. Expect some BFH though. Hopefully you have 17x11s in the rear running a 315
Old Jan 3, 2008 | 04:31 PM
black383's Avatar
i plan on getting the the 17x11 zr1 for the back, but i wanted to make sure that will fit without issue before i started ordering stuff... can i go any bigger that that or is that biggest i have to go before mini tube?
Old Jan 3, 2008 | 06:12 PM
Nacho SS's Avatar
Some people can pull off 12" without a mini-tub with some BFH.....but if you are lowered , its probably a no go.
Old Jan 3, 2008 | 06:25 PM
black383's Avatar
bfh?......
hpjunky98's Avatar
They'll fit with the right offset. You will need to beat the inner fenders to clearance them for the tire.. how much you'll need to BFH the car depends on the tire manufacturer. Im lowered quite a bit at this point, and the 315 GSD3s on 11.5inch wide rims fit without issues.
Old Jan 3, 2008 | 06:59 PM
black383's Avatar
i wanted to go with the 17x11 ZR1's with 315/35/17 nitto drag radial
