People with painted rims
Old Jan 8, 2008 | 02:34 AM
unknown pontiac's Avatar
Default People with painted rims
I just wanted to know if you left your tires on when you painted your rims or you took them off. I am going to paint my stock rims black. I have seen alot of good pic of painted rims that some of you guys did. Why would I paint my rims, because it's cheaper then powder coating. If it chips or look bad I dont care I going to get rims very very soon. It just something for now. I want the new ZR1's in black with polished lip. if the rims turn out nice I will wait for the ZR1's if it looks bad I just get something dif and get the ZR1's later.
Old Jan 8, 2008 | 09:00 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Keep in mind that if you do paint them and it chips and looks like crap, you are stuck with them. Nobody would buy them, if that is a concern.
You have to clean the wheels REALLY good if they are used. Scuff the surface a little with a 3M Scotchbrite pad, then primer them, then 3 or so coats of color, then 2 coats of clear. That should last a little longer than a quick spray job.
Old Jan 8, 2008 | 01:06 PM
blackls1maro's Avatar
it's possible to paint the rims with the tires left on, just make sure you mask off the tire at the edge of the wheel.
Old Jan 8, 2008 | 07:58 PM
So it is ok to leave my tire on the rims.
Old Jan 8, 2008 | 10:20 PM
whyte95ZRida's Avatar
I took my tires off when i did my old zo6's. Then i covered them with aircraft stripper and got all the old paint off. After that I did a small amount of scuffing and sanding. Primered them, then 4 coats of color(gradually got heavier in each coat), and 3 of clear(first light and then two heavy).
Sold the wheels about 5 months later for almost double what I gave my buddy for them.
Old Jan 9, 2008 | 03:53 AM
Thanks for your help. I hope I can sell mine after I get the rims I want.
Old Jan 9, 2008 | 09:30 AM
NVR_SPDS's Avatar
One thing that may help masking the tire, is to use a deck of playing cards. You can slide them in behind the wheel lip a little to help mask the tire better.
Old Jan 9, 2008 | 11:37 AM
balbosky01's Avatar
I left my tires on and just covered them really well. What kind of wheels are you painting?? Im assuming the aluminum ws6 wheels??
Old Jan 9, 2008 | 06:02 PM
I am doing the rims on my camaro. The firebird is just a v6 DD it looks good with the rims on it now.
Attached Thumbnails People with painted rims-maro.jpg   People with painted rims-100_0019.jpg   People with painted rims-100_0020.jpg
Old Jan 10, 2008 | 02:42 PM
99DWPTA's Avatar
I have a freind that paints his rims all the time and he takes playing card and sticks them around the rim and they come out good. I think it is better then masking tape. hope it helps
Old Jan 12, 2008 | 02:14 AM
I will post up picks after I paint them. Thanks for the playing cards trick I will make sure I use them.
Old Jan 29, 2008 | 11:53 PM
chrisout's Avatar
I just picked up a 2000 SS and it had painted SS rims. My daughter wanted to drive it and in one trip to the store, she came back with it looking like the pictures I have here! it looks GETTO! You can redo them and I will but it is an extreme pain in the butt. I am going to but am upgrading to vette rims if I can.in the mean time I wont even drive it this way.
Attached Thumbnails People with painted rims-3bc5_3.jpg   People with painted rims-57fd_3.jpg
Old Jan 30, 2008 | 12:02 AM
chromeplated500's Avatar
i actually like your SS... personal choice i guess..
Old Jan 30, 2008 | 06:14 AM
BIG_MIKE2005's Avatar
Damn, you should have taught her to drive better. Hit curbs on both sides, good lord.
Old Jan 30, 2008 | 06:27 AM
streetassasin's Avatar
If you paint ttem black try to keep a silver lip or it wont look right, It'll seem like the rim and tire are one piece. Personally I say give tomz a call or go with gunmetal paint
Old Jan 30, 2008 | 10:25 AM
shiv15's Avatar
What Tony said is the process to follow.
I left tires on and had no issues with it.
I actually painted my wheels twice (posted pics of both). The first came out really good but I wanted to have a shine to the lip. The second time I was planning on changing the silver lip to the polished metal underneath but the aircraft stripper messed up so I just painted the wheels all black. The stripper really screwed up the wheels finish. I tried to sand it down but that proved to me a longer than enjoyable process. They did come out fine as all black and I actually enjoy the way they look but two wheels are bent anyways so it wasn't much of a concern with long term usage.
Old Jan 30, 2008 | 03:01 PM
atxz/28maro's Avatar
I painted my zr1's black, just got them on yesterday. they turned out great! duplicolor black and clear (3 coats of each), it's all in the prep time, i took at least an hour per wheel sanding and prepping
Old Jan 31, 2008 | 02:26 AM
chrisout's Avatar
I know! I was so pissed! I am still debating what to do. redo them, get Z06's or some others.
Old Jan 31, 2008 | 02:34 AM
chrisout's Avatar
What I meant was that they look terrible rashed, they look pretty good blacked out. I was out today and there were two other SS's in town and they both had theirs blacked out. Seeing the cars in motion gives you a different perspective. Looks more race than stock. One of them has a red hand painted pin stripe on the lip and his were painted gloss black. It really looked great.
My car has TRW drilled and slotted rotors and I think that really tops it off.
Chris.
Old Jan 31, 2008 | 06:51 AM
socmguy's Avatar
Restricted User
I have an extra set of wheels like the OP has and was going to powdercoat them in my garage. I was thinking about using matte black. What does everyone think?
