Just want to make sure....
Old Jan 17, 2008 | 06:40 AM
State69champ's Avatar
Default Just want to make sure....
Quick Question....
I just want to make sure that if I buy these rims theywill fit.
http://www.wheelhq.com/hypersilver-c...x95-wheel.html
Bolt Pattern: 5x4.75 inch
(5x120.65mm)
The reason im asking if b/c I bought a set of newer f-body rims for my lt1 and they would not fit on the back.. will I have troubles if i but these...
also.. Will there pr problems if i get 8.5" up from and 9.5" in the back? the off set one the 8.5" is +56mm and the 9.5 is +50mm will it looks funny at all?
Old Jan 17, 2008 | 07:20 AM
OSUBraden's Avatar
The link you posted doesn't show a specific wheel, just the main website. You may want to check out TomzWheels.com and compare prices too...
Old Jan 17, 2008 | 08:58 AM
ok so I checked the site out and they have the wheels I want a for a good price but they dont have the finish im looking for.
Old Jan 17, 2008 | 09:08 AM
there is a pic.. the question is. is it going to fit on my car?? with the bolt pattern above?
like i said i ried to put newer wheels on my car befoe but they did not want oo fit over the center hub in the back
Old Jan 17, 2008 | 10:45 AM
DopdBrd's Avatar
They didn't fit over the center hub because the older F body's (96 and older I believe) had a bigger center hub than the newer ones (97+). You don't want to try and force them on either.
Old Jan 17, 2008 | 11:33 AM
Xsta Z 28's Avatar
Originally Posted by State69champ
like I said I tried to put newer wheels on my car before but they did not want too fit over the center hub in the back
That is normal. Either ream the hole out a little bit, or better yet, cut the hub button diameter down so the wheel fits over it.
