LT1 wheel on LS1 Q
Old Jan 17, 2008 | 09:48 AM
EPMD's Avatar
Default LT1 wheel on LS1 Q
Is there any problems fitting a 16 x 8 wheel off a 97 trans am on a 00 WS-6. Just going to use them for drag radials. Thanks in advance
Old Jan 17, 2008 | 10:46 AM
DopdBrd's Avatar
No they should be fine. It's when you try fitting a newer wheel on an older F body that you run into problems because the have a smaller hub. But 97+ all had the same size of hub.
