Will these AZA wheels work? Bolt pattern slightly smaller.
. I wish they came in a 17x10.5. Also what do you guys think about running 18s vs 17s? Do the 18s hurt performance alot?http://www.wheelmax.com/product.asp?ProdId=21771
Thanks
Thanks
L8tr
They look very similar to fikse wheels. I'm suprised more people don't have an intersest in them. Last edited by slow89rs; Jan 20, 2008 at 07:10 PM.
But . . . it is techincally the wrong bolt pattern, just so you know . . .
Yes many people run that bolt pattern with no issues . . .
And YES people have had problems - I.E. wheel fell off, stud(s) broke . . .
It is your car and your choice. Keep in mind your 4 wheels and tires are the ONLY thing keeping your car shiney side up.
but to the point at hand, i havent had a problem with the bolt pattern, and ive been running them for awhile. not to say the true 120.65 pattern wouldnt be preferred, but they will work just fine..most of the time youll know during the torquing of the lug nuts if youll have the problem...and itll be obvious...youll bust a stud right there. as for losing a tire, well, thatll happen if you forget to tighten the lug nuts regardless, so just dont forget that, and youll be fine
120.65mm vs. 120mm is 0.65mm difference or just over a half of a millimeter. Translated into a 4-bolt pattern this would mean that each lug is off (the 120.65mm) center by 0.325mm. However, in our case we are in fact dealing with a 5-bolt pattern:
The lug circle in a 4-bolt pattern is equivalent to the diameter of the circle that the lugs form. The lug circle in a 5-bolt pattern however, is not. Since you take the distance between any two opposing lugs, you are not getting a diameter, you are getting a tangent. So it's not as cut-and-dry as it is with a 4-bolt pattern (where you just divide the difference between the two circles by 2 to get the differential). In a 4-bolt pattern, the diameter increases linearly with the lug circle, since they are equivalent. In the case of the 5-bolt pattern, the tangent line that defines the lug circle actually increases at a significantly higher rate than the actual diameter of the circle that the lugs form. I'm not even going to try to work through the calc-ridden equation required to figure out the actual differential, but I can tell you that the result is less than 0.2mm.
Why is this important? The deflection of aluminum and almost all alloys made from it is well above 0.2mm at 100ft/lbs (recommended lug torque spec).
Translation: you will actually slightly modify the lug holes on the wheels before you bend even the factory studs on our cars when installing 5x120mm bolt pattern wheels.
This does however make the hubcentric (or centerbore) adapters extremely important in this case.
