Will rims fit
Another option that you could do is run a 255/40r17 in the front giving you an overall diameter of 24.9 and running a 285/35r18 on the rear which would have an overall diameter of 25.9. The extra inch is in the rim diameter thus giving you the same sidewall height in the front and the back. This setup would definitely not give you any clearance problems. And ovbviously this would also give you a lower profile look. Either way i dont think you would have any clearance problems going with a 285 tire in the back.
Hope my long saga helps you out!!!!
i just know that i have a blazer right now and put tires on that "should" fit and not rub
but of course they do
285's thanks gotta rememeber that
