Nitto 555r Psi??
Old Jan 29, 2008 | 10:33 PM
Blknight6989's Avatar
Default Nitto 555r Psi??
I'm running Nitto 555r Dr's. What psi you guys run when drag racing??? This will mostly be on the street.
Old Jan 29, 2008 | 10:38 PM
LS1crazy01's Avatar
Steet I run 32 on the steet, and track depending on conditions 12-15.
Old Jan 29, 2008 | 11:00 PM
ta_06374's Avatar
What size are they? 30 cold here for the street.
Old Jan 30, 2008 | 05:43 AM
streetassasin's Avatar
Damn I run 23psi on the street
Old Jan 30, 2008 | 01:48 PM
shaun's Avatar
i run about 28 on the street and the same at the track. i used to run about 18 at the track but it was slowing me down on the big end at the track so i slowly kept adding more air till i got to about 26-28 at the track and i hooks just as good as long at there heated up good.most guys run lower psi but my car has some rear suspention work so maybe it hooks a little better that a stock suspention car. plus if you run to much the centers will wear out faster and to less will wear the out side so about 28 works good for me.
