How well will these fit?
Old Jan 31, 2008 | 11:20 PM
Spiers's Avatar
Exclamation How well will these fit?
Hey guys I found me some rims and I'm wondering how well they will fit...anyone have pics with the same wheel specs?
19x8 40mm offset
19x9.5 45mm offset
They are advertised as 5x120 for BMW and 93+ FBody...
Old Jan 31, 2008 | 11:52 PM
The Guz's Avatar
The bolt pattern is not exact but they will fit. More info in the wheel sticky.
https://ls1tech.com/forums/wheels-tires/120716-wheels-tires-everything-you-should-need-know-here-must-read.html
Old Feb 1, 2008 | 12:42 AM
TransAm Mania's Avatar
https://ls1tech.com/forums/showthread.php?t=120716
If the bolt pattern is not exact, DO NOT go with them. They may seem to fit but the lugs won't seat properly and will eventually come loose. Good way for a wheel to fall off.
