Buying MT ets/ with Cregers
Old Feb 22, 2008 | 03:22 AM
02_ramair_ta's Avatar
Exclamation Buying MT ets/ with Cregers
I am looking at a set of MT 28x10x15 ets, but the real question is, they are mounted on a set of creger soft 8 (the cheap ones) The wheel measures 15x10 with a 4 inch backspacing and an -38mm offset. now I looked at the rim/tire guide and I couldnt figure this out, but before I buy these I wanted to know if they will fit, or if I would have to roll the wheel wells out, and mini tub the car? I think 28" should fit, but with a 10 inch wide tire, I am not too sure about that wheel off set, and backspacing stuff. Please help...
Old Feb 22, 2008 | 06:32 AM
Tally TransAm's Avatar
not gonna fit
Old Feb 22, 2008 | 07:43 AM
What is gunna make it not fit? is it going to stick out too much, or is it going to rub inside? is it something I could fix with a different rim, and if so any size ideas??
Old Feb 22, 2008 | 08:06 AM
stevensLS1's Avatar
the back spacing on drag wheels like pro stars is 7.5. if you run a 4" backspacing you will need a narrowed rear end.
Old Feb 22, 2008 | 08:14 AM
So a different set of rims, with more back spacing would do the trick? The rims from creger are only like 40.00 a piece, so if its something I could fix right there, I would much rather go that route. So would you say I would need 7.5 in backspacing?
Old Feb 22, 2008 | 08:43 AM
Camaro396's Avatar
what exactly is a creger?
Old Feb 22, 2008 | 08:50 AM
Sorry that was CRAGAR.. hahaha... I didnt notice that till you said something..
